Salta al contenuto principale
Coolpad Defiant Battery Replacement
Cosa ti serve
  1. Coolpad Defiant Battery Replacement, Back Cover: passo 1, immagine 1 di 2 Coolpad Defiant Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Battery Replacement: passo 2, immagine 1 di 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,443
