Salta al contenuto principale
Coolpad Defiant Back Case Replacement
Cosa ti serve
  1. Coolpad Defiant Back Case Replacement, Back Cover: passo 1, immagine 1 di 2 Coolpad Defiant Back Case Replacement, Back Cover: passo 1, immagine 2 di 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Back Case Replacement: passo 2, immagine 1 di 1
    • Remove the back cover from your device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 317
