Salta al contenuto principale
Converting iMac Intel 27" to an USB-C monitor with 30W charging
Cosa ti serve
  1. Converting iMac Intel 27" to an USB-C monitor with 30W charging, Remove stuff: passo 1, immagine 1 di 1
    • Follow teardown guide to remove logic board, video card, hard drive
    • Connect Driver Board to display
    • I got mine here. https://item.taobao.com/item.htm?id=5381...
    • Connect a DisplayPort (male) to mini DisplayPort (female) cable to the driver board and hotglue the female end to the iMac back panel
  2. Converting iMac Intel 27" to an USB-C monitor with 30W charging, Connect Power to Driver board: passo 3, immagine 1 di 1
    • (Optional) If you want to use the original iMac power button, connect the switch to the 12v latching module, PP12V_G3H + GND to power in, and connect the PS_ON pin to the output. Latching module should be configured to pull to ground when "on"
    • If you just want it to be always on and use the driver power button, short PS_ON to GND
    • Pinout guides here: Can anyone tell me what these PSU pin abbreviations mean? PSU 614-0446
  3. Converting iMac Intel 27" to an USB-C monitor with 30W charging, Hook up internal USB devices: passo 4, immagine 1 di 3 Converting iMac Intel 27" to an USB-C monitor with 30W charging, Hook up internal USB devices: passo 4, immagine 2 di 3 Converting iMac Intel 27" to an USB-C monitor with 30W charging, Hook up internal USB devices: passo 4, immagine 3 di 3
    • Disassemble USB Man-style hub, cut cables, insert USB sockets into usb openings, hot glue USB ports from the inside and solder everything back together
    • Something like this... https://www.amazon.com/Kikkerland-US006-...
    • you need another 5v/12v powered 4 port hub to connect the iSight, SuperDrive, SD Card Reader and the rear ports. And some donor USB cables...
    • iSight Pinout +5v = brown, D+ = Purple, D-= grey GND=black. Unfortunately Apple uses different colors for different revisions. Pinout of the iMac's built in iSight..
    • SD Card Reader Pinout +5v = orange, D+ = grey, D-= purple, GND=unshielded cable. Again, Apple uses different colors for different revisions, although you'd think the cabling color scheme would be at least internally consistent.... https://www.tonymacx86.com/threads/apple...
    • Connect the USB-SATA bridge to the SuperDrive and the USB hub. I had to cut away some plastic to fit the USB adapter
    • Power the USB hubs with the 12v pins, or use a DC-to-DC stepdown board to convert 12v to 5v. (The power supply doesn't provide a 5v rail...)
  4. Converting iMac Intel 27" to an USB-C monitor with 30W charging, Bonus steps: passo 5, immagine 1 di 2 Converting iMac Intel 27" to an USB-C monitor with 30W charging, Bonus steps: passo 5, immagine 2 di 2
    • Thinking about getting the speakers and Mic working as well. We are going to need a USB soundcard and an amplifier that can handle driving the built in 17W speakers
    • DIYaudio.com seems like a pretty deep pit to jump in.
    • Do I need a fan controller? I think I need a fan controller.
Conclusione
Raf
Membro da: 09/16/20
193 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 68
Tutti i Tempi: 2,816
