Salta al contenuto principale
Contour Roam2 Waterproof Action Camera Record Slider Replacement
Cosa ti serve
  1. Contour Roam2 Waterproof Action Camera Record Slider Replacement, Record Slider: passo 1, immagine 1 di 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 2, immagine 1 di 2 Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 2, immagine 2 di 2
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 3, immagine 1 di 2 Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 3, immagine 2 di 2
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
  4. Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 4, immagine 1 di 3 Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 4, immagine 2 di 3 Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 4, immagine 3 di 3
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
  5. Contour Roam2 Waterproof Action Camera Record Slider Replacement: passo 5, immagine 1 di 1
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
Conclusione
Altre 3 persone hanno completato questa guida.
2 Commenti
I have had this camera since I was 16 I am 21 now and there was something wrong with the slider I am glad I didn't get rid of it! Because of you it is fixed now!!!
Neiko Rivera (Specters) - Replica
Dose anyone know if there is an equivalent guide but for the “Contour +2”?
Christopher Hinrichs - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 909
