Salta al contenuto principale
Contour Roam2 Rotating Lens Replacement
Cosa ti serve
  1. Contour Roam2 Rotating Lens Replacement, Rotating Lens: passo 1, immagine 1 di 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Rotating Lens Replacement: passo 2, immagine 1 di 2 Contour Roam2 Rotating Lens Replacement: passo 2, immagine 2 di 2
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Rotating Lens Replacement: passo 3, immagine 1 di 1
    • Use a spudger to pry up the black rubber ring around the lens cover.
    • The black rubber ring is vey thin and can easily tear. Use caution when removing.
  4. Contour Roam2 Rotating Lens Replacement: passo 4, immagine 1 di 1
    • Remove and replace the lens cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 716
