Salta al contenuto principale
Contour Roam2 Back Door Replacement
Cosa ti serve
  1. Contour Roam2 Back Door Replacement, Record Slider: passo 1, immagine 1 di 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Back Door Replacement: passo 2, immagine 1 di 2 Contour Roam2 Back Door Replacement: passo 2, immagine 2 di 2
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Back Door Replacement: passo 3, immagine 1 di 2 Contour Roam2 Back Door Replacement: passo 3, immagine 2 di 2
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
  4. Contour Roam2 Back Door Replacement: passo 4, immagine 1 di 3 Contour Roam2 Back Door Replacement: passo 4, immagine 2 di 3 Contour Roam2 Back Door Replacement: passo 4, immagine 3 di 3
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
  5. Contour Roam2 Back Door Replacement: passo 5, immagine 1 di 1
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
  6. Contour Roam2 Back Door Replacement, Mounting Piece: passo 6, immagine 1 di 2 Contour Roam2 Back Door Replacement, Mounting Piece: passo 6, immagine 2 di 2
    • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
  7. Contour Roam2 Back Door Replacement: passo 7, immagine 1 di 2 Contour Roam2 Back Door Replacement: passo 7, immagine 2 di 2
    • Open the back door by your thumb and index finger on sides of back door and pull upward.
  8. Contour Roam2 Back Door Replacement: passo 8, immagine 1 di 1
    • Using your thumb, pry sides outward on back of mount piece.
    • This will loosen mount piece for removal in proceeding step.
    • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
  9. Contour Roam2 Back Door Replacement: passo 9, immagine 1 di 2 Contour Roam2 Back Door Replacement: passo 9, immagine 2 di 2
    • Remove and replace mount piece.
  10. Contour Roam2 Back Door Replacement, Back Door: passo 10, immagine 1 di 1
    • Using a paper clip or a SIM eject tool size 0.8, push the metal bar out from the spring located on bottom of back door.
    • After removing the metal bar, the spring will become loose and may fall out on its own.
  11. Contour Roam2 Back Door Replacement: passo 11, immagine 1 di 1
    • Remove and replace back door.
    • Door should easily be removed by pulling away from main body of camera.
    • As door is being pulled away, the spring may fall out own its own.
Conclusione
Jamie Maple
Membro da: 03/11/15
310 Reputazione
2 Guide realizzate
Un commento
Where can I get a replacement back door for an original contour roam shipped international? Contour will not reapond to my requests.
The Dude - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,513
