Salta al contenuto principale
Connecting Cables to the Motherboard
Cosa ti serve
  1. Connecting Cables to the Motherboard, Connecting Cables to the Motherboard: passo 1, immagine 1 di 2 Connecting Cables to the Motherboard, Connecting Cables to the Motherboard: passo 1, immagine 2 di 2
    • Red- Optional ATX Connector
    • Orange- CPU Fan 1
    • Yellow- CPU Fan 2
    • Green- Main ATX Connectors
    • Light Blue- GPU
    • Blue- Panel Connectors
    • Pink- USB Connectors
    • Black- HD Audio
    Chiedi a FixBot
    Aggiungi Commento
  2. Connecting Cables to the Motherboard, Optional ATX Connector: passo 2, immagine 1 di 2 Connecting Cables to the Motherboard, Optional ATX Connector: passo 2, immagine 2 di 2
    • Connect the two separate six-pin segments to six pins each on the 12-pin PCIE port.
    Chiedi a FixBot
    Aggiungi Commento
  3. Connecting Cables to the Motherboard, CPU Fan 1: passo 3, immagine 1 di 2 Connecting Cables to the Motherboard, CPU Fan 1: passo 3, immagine 2 di 2
    • Connect the four pin segment to the four pin PCEI connector labeled "CPUFAN1."
    Chiedi a FixBot
    Aggiungi Commento
  4. Connecting Cables to the Motherboard, CPU Fan 2: passo 4, immagine 1 di 2 Connecting Cables to the Motherboard, CPU Fan 2: passo 4, immagine 2 di 2
    • Connect the four pin segment to the four pin PCIE port labeled "CPUFAN2."
    Chiedi a FixBot
    Aggiungi Commento
  5. Connecting Cables to the Motherboard, Main ATX Connector: passo 5, immagine 1 di 2 Connecting Cables to the Motherboard, Main ATX Connector: passo 5, immagine 2 di 2
    • Connect the 24 pin segment to the 24 pin PCIE port.
    Chiedi a FixBot
    Aggiungi Commento
  6. Connecting Cables to the Motherboard, GPU: passo 6, immagine 1 di 2 Connecting Cables to the Motherboard, GPU: passo 6, immagine 2 di 2
    • Connect both of the separate eight pin segments to each of the eight pin PCIE ports on the graphics card.
    Chiedi a FixBot
    Aggiungi Commento
  7. Connecting Cables to the Motherboard, Panel Connectors (Part 1): passo 7, immagine 1 di 3 Connecting Cables to the Motherboard, Panel Connectors (Part 1): passo 7, immagine 2 di 3 Connecting Cables to the Motherboard, Panel Connectors (Part 1): passo 7, immagine 3 di 3
    • This PCIE port consists of eight pins, two rows of four.
    • Connect the "Power LED+" pin to the pin at the top right corner.
    • Connect the "Power LED-" segment to the pin next to the "Power LED+" segment in the top row.
    • Connect the "Power SW" segment to the two pins on the left side of the top row of pins.
    Chiedi a FixBot
    Aggiungi Commento
  8. Connecting Cables to the Motherboard, Panel Connectors (Part 2): passo 8, immagine 1 di 3 Connecting Cables to the Motherboard, Panel Connectors (Part 2): passo 8, immagine 2 di 3 Connecting Cables to the Motherboard, Panel Connectors (Part 2): passo 8, immagine 3 di 3
    • Connect the "HDD LED" segment to the two pins on the right side of the bottom row of pins.
    • Connect the "Reset SW" segment to the two pins on the left side of the bottom row of pins.
    Chiedi a FixBot
    Aggiungi Commento
  9. Connecting Cables to the Motherboard, USB Connector: passo 9, immagine 1 di 2 Connecting Cables to the Motherboard, USB Connector: passo 9, immagine 2 di 2
    • Connect the nine pin segment to the nine pin PCIE port.
    Chiedi a FixBot
    Aggiungi Commento
  10. Connecting Cables to the Motherboard, HD Audio: passo 10, immagine 1 di 2 Connecting Cables to the Motherboard, HD Audio: passo 10, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To disconnect the cable ties, follow these directions in reverse order.
Altre 2 persone hanno completato questa guida.
1Commento della guida
Rest comment brancher un processeur. Merci comme-me.
Kader Lahcene - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 43
Ultimi 7 giorni: 256
Ultimi 30 giorni: 1,048
Tutti i Tempi: 27,418
