Salta al contenuto principale
Connect Four Electronic Handheld Battery Compartment Replacement
Cosa ti serve
  1. Connect Four Electronic Handheld Battery Compartment Replacement, Ensure the device is off.: passo 1, immagine 1 di 1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Battery Compartment Replacement, Removing the battery casing.: passo 2, immagine 1 di 2 Connect Four Electronic Handheld Battery Compartment Replacement, Removing the battery casing.: passo 2, immagine 2 di 2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
Conclusione
Kamaryn
Membro da: 10/22/14
225 Reputazione
2 Guide realizzate
Baylor, Team 8-11, Williams Fall 2014 Membro di Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 120
