Salta al contenuto principale
Connect Four Electronic Handheld Back Casing Replacement
Cosa ti serve
    1. Connect Four Electronic Handheld Back Casing Replacement, Ensure the device is off.: passo 1, immagine 1 di 1
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      Chiedi a FixBot
      Aggiungi Commento
    2. Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: passo 2, immagine 1 di 2 Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: passo 2, immagine 2 di 2
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      Chiedi a FixBot
      Aggiungi Commento
    1. Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: passo 3, immagine 1 di 2 Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: passo 3, immagine 2 di 2
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Wil
Membro da: 10/22/14
313 Reputazione
3 guide realizzate
Baylor, Team 8-11, Williams Fall 2014 Membro di Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Membri
36 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 36
Tutti i Tempi: 498
