Salta al contenuto principale
Conair Infiniti PRO Curling Iron Power Cord Replacement
Cosa ti serve
  1. Conair Infiniti PRO Curling Iron Power Cord Replacement, Housing: passo 1, immagine 1 di 1
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Power Cord Replacement: passo 2, immagine 1 di 1
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Power Cord Replacement: passo 3, immagine 1 di 3 Conair Infiniti PRO Curling Iron Power Cord Replacement: passo 3, immagine 2 di 3 Conair Infiniti PRO Curling Iron Power Cord Replacement: passo 3, immagine 3 di 3
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Power Cord Replacement, Power Cord: passo 4, immagine 1 di 1
    • Pull power chord out.
Conclusione
IUPUI, Team S7-G5, Baechle Fall 2017 Membro di IUPUI, Team S7-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G5
3 Membri
5 Guide realizzate
3 Commenti
Where do I find the cords needed for the repair I've looked everywhere
John Cornelison - Replica
I also couldn’t find the needed cord.
C vd Linden - Replica
I'm surprised that anyone won a prize for these instructions when they've left out the source of their replacement cord.
The replacement power cords are apparently mythical by this time, and I think that Global Beauty bit the dust as well. But if you disassemble the swivel (the part with the sliding electrical contacts) you may notice that the "male" portion of the swivel assembly looks like you could dig or drill out the broken wires and solder in the inner wires of the existing power cord, which will render the cord a bit shorter. You'll also need some sort of flexible strain relief, and I think that the old one could be cut off the discarded portion of the old power cord and glued (with cyanoacrylate, or Super Glue) back onto the cord.
Mark Kinsler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 32
Tutti i Tempi: 2,418
