Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide requires the removal of the housing which takes some time and work. However, after this the removal and replacement of the power cord is really simple.
Parti
Nessuna parte specificata.
  1. Remove the Philips #1 28 mm.
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Remove the Philips #1 22 mm screws.
    • Remove the Philips #1 22 mm screws.
  3. Pry off the housing using a plastic spudger. Pry off the housing using a plastic spudger. Pry off the housing using a plastic spudger.
    • Pry off the housing using a plastic spudger.
  4. Pull power chord out.
    • Pull power chord out.
Conclusione
Jonathon Bruer
Membro da: 09/11/2017
580 Reputazione
5 Guide realizzate
IUPUI, Team S7-G5, Baechle Fall 2017 Membro di IUPUI, Team S7-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G5
3 Membri
5 Guide realizzate
Where do I find the cords needed for the repair I've looked everywhere
John Cornelison - Replica
I also couldn’t find the needed cord.
C vd Linden - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,139
