Salta al contenuto principale
Introduzione
This guide will show how to remove the housing from the curling iron. This step is useful in most of the other replacement guides for this device.
Parti
Nessuna parte specificata.
  1. Remove the Philips #1 28 mm.
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Remove the Philips #1 22 mm screws.
    • Remove the Philips #1 22 mm screws.
  3. Pry off the housing using a plastic spudger. Pry off the housing using a plastic spudger. Pry off the housing using a plastic spudger.
    • Pry off the housing using a plastic spudger.
Conclusione
Jonathon Bruer
Membro da: 09/11/2017
553 Reputazione
5 Guide realizzate
IUPUI, Team S7-G5, Baechle Fall 2017 Membro di IUPUI, Team S7-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G5
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 21
