Salta al contenuto principale
Conair Infiniti PRO Curling Iron Heating Element Replacement
Cosa ti serve
  1. Conair Infiniti PRO Curling Iron Heating Element Replacement, Housing: passo 1, immagine 1 di 1
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 2, immagine 1 di 1
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 3, immagine 1 di 3 Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 3, immagine 2 di 3 Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 3, immagine 3 di 3
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Heating Element Replacement, Power Cord: passo 4, immagine 1 di 1
    • Pull power chord out.
  5. Conair Infiniti PRO Curling Iron Heating Element Replacement, Motherboard: passo 5, immagine 1 di 1
    • Heat up your soldering gun and desolder the red wire from the motherboard as shown.
    • Note the location of wire attachment.
  6. Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
    • With your soldering gun, desolder the white wire from the motherboard as shown.
  7. Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 7, immagine 1 di 1
    • Once both wires are desoldered the motherboard can be removed.
  8. Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: passo 8, immagine 1 di 2 Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: passo 8, immagine 2 di 2
    • Remove the heating element mount. This will free up the heating element barrel for replacement.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team S7-G5, Baechle Fall 2017 Membro di IUPUI, Team S7-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,502
