Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Macintosh Color Classic, usa il nostro manuale di assistenza.
  1. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside), Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 1, immagine 1 di 1
    • My Macintosh Color Classic running under MacOS 7.6 some days before it died
  2. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 2, immagine 1 di 1
    • Machine completely emptied
  3. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 3, immagine 1 di 1
    • all original components…
  4. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 4, immagine 1 di 1
    • ...were replaced with the new ones
  5. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 5, immagine 1 di 1
    • Testing the new HDMI 8” LCD screen.
  6. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 6, immagine 1 di 1
    • The chassis and the power supply board were cleaned up and adapted for fitting the new components.
  7. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 7, immagine 1 di 1
    • Installing the new screen
  8. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 8, immagine 1 di 1
    • Closing the back case
  9. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 9, immagine 1 di 1
    • Sliding in and connecting the MacMini 2014
  10. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 10, immagine 1 di 1
    • Closing the clip-in backplane
  11. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 11, immagine 1 di 1
    • Plugging in the computer
  12. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 12, immagine 1 di 1
    • Starting the computer
  13. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 13, immagine 1 di 1
    • Macintosh Color Classic running under MacOS Mojave
  14. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 14, immagine 1 di 3 Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 14, immagine 2 di 3 Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): passo 14, immagine 3 di 3
    • Insert wisdom here.
Roberto
Membro da: 06/08/17
245 Reputazione
1 Guida realizzata
12 Commenti
Wow, such a clean built. Thanks for sharing!
Luke - Replica
La pantalla es lo que mas temor da retirar si es igual a las de la emac y imacs, me gustaría haberlo hecho con la que me dañaron en un taller, no la guarde y tire la basura, en fin jamas se sabe lo que la tecnología nueva nos permite hacer con las viejas carcazas, debe ser grato ver la cara de la gente que te ve trabajar en ella con teclado y ratón inalámbricos.
javiersconde - Replica
Do you have a more detailed breakdown, including exact parts used. I have one of these Macs and it has died. The sentimental value is huge so doing to it what you did to yours is an awesome idea. Thanks
Nathan Fletcher - Replica
Sorry, I haven’t more details of the breakdown. The most difficult part was to clean up the power supply board and to saw parts of the plastic chassis to fit the MacMini inside. The parts I kept from the original machine are the chassis, the power supply board and the framework that sustained the original screen.
Roberto -
Roberto, what size is the fan? 60x25mm? And can you remove the stock fan from that metal housing so as to replace it with a quieter modern version? Thanks.
James Wages - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,185
