Salta al contenuto principale
Compaq iPAQ Pocket PC 3830 Battery Replacement
Cosa ti serve
  1. Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: passo 1, immagine 1 di 2 Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: passo 1, immagine 2 di 2
    • Remove the four 0.8 mm Phillips #00 screws from the back cover.
  2. Compaq iPAQ Pocket PC 3830 Battery Replacement: passo 2, immagine 1 di 1
    • Detach the yellow wire from comb that is attached to the battery.
  3. Compaq iPAQ Pocket PC 3830 Battery Replacement: passo 3, immagine 1 di 1
    • The yellow wire is removed from the comb attached to the battery.
  4. Compaq iPAQ Pocket PC 3830 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery using tweezers from back cover.
  5. Compaq iPAQ Pocket PC 3830 Battery Replacement: passo 5, immagine 1 di 1
    • Detach the battery from back cover.
Conclusione
Altre 3 persone hanno completato questa guida.
2 Commenti
One question; Where can I get a new battery????
Every place I have looked have a smaller batter,  not like the one you show.
Stephen
oharasc85@gmail.com
Stephen O'Hara - Replica
we are in need of battery
Danionics DLP 305590
Quantity : 02 Nos.
Please send us the lowest estimate.
Mail ID: electronics@pmtpims.org
ELECTRONICS1 PIMS - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 3,143
