Salta al contenuto principale
Compaq Presario v2000 RAM Replacement
Cosa ti serve
  1. Compaq Presario v2000 RAM Replacement, Removing the RAM cover: passo 1, immagine 1 di 2 Compaq Presario v2000 RAM Replacement, Removing the RAM cover: passo 1, immagine 2 di 2
    • Loosen the 2 Phillips screws with RAM icons above them. Don’t worry if the screws won’t come out, as they’re attached to the door.
    • Lift the RAM door up and away.
  2. Compaq Presario v2000 RAM Replacement, Removing the existing RAM: passo 2, immagine 1 di 3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: passo 2, immagine 2 di 3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: passo 2, immagine 3 di 3
    • There are two metal clips holding both RAM modules in place.
    • To unclip them, push them both outwards from the RAM stick with your fingers until it pops out and sticks up at an angle.
    • Pull the stick of RAM out.
    • Repeat the last 3 steps for the bottom RAM stick.
  3. Compaq Presario v2000 RAM Replacement, Installing the new RAM: passo 3, immagine 1 di 2 Compaq Presario v2000 RAM Replacement, Installing the new RAM: passo 3, immagine 2 di 2
    • Start at the bottom slot. Insert the new RAM at the same angle the previous RAM popped out at.
    • Push the RAM in until a click is heard.
    • Repeat the last 2 steps for the top slot.
  4. Compaq Presario v2000 RAM Replacement, Reinstalling the RAM cover: passo 4, immagine 1 di 1
    • Repeat the first part of this guide to reinstall the RAM door.
Conclusione
If you encounter problems after installing new RAM, redo this guide, or follow a RAM troubleshooting guide.
Viscous
Membro da: 02/02/24
381 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 276
