Salta al contenuto principale
Compaq Presario V2414NR WiFi Card Replacement
Cosa ti serve
  1. Compaq Presario V2414NR WiFi Card Replacement, Battery: passo 1, immagine 1 di 1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR WiFi Card Replacement: passo 2, immagine 1 di 2 Compaq Presario V2414NR WiFi Card Replacement: passo 2, immagine 2 di 2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR WiFi Card Replacement, RAM Cover: passo 3, immagine 1 di 2 Compaq Presario V2414NR WiFi Card Replacement, RAM Cover: passo 3, immagine 2 di 2
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR WiFi Card Replacement, WiFi Card: passo 4, immagine 1 di 2 Compaq Presario V2414NR WiFi Card Replacement, WiFi Card: passo 4, immagine 2 di 2
    • Loosen the 5mm Phillips #1 screw that secures the Mini PCI compartment cover to the computer.
    • This screw is captured to the cover panel.
    • Lift the rear edge of the Mini PCI compartment cover, and swing it forward to remove it.
  5. Compaq Presario V2414NR WiFi Card Replacement: passo 5, immagine 1 di 2 Compaq Presario V2414NR WiFi Card Replacement: passo 5, immagine 2 di 2
    • Make note of which cable is attached to which clip on the WiFi card before disconnecting the cables.
    • Disconnect the wireless antenna cables from the WiFi card by prying gently upwards on the metal part of the connector with a spudger or plastic opening tool.
  6. Compaq Presario V2414NR WiFi Card Replacement: passo 6, immagine 1 di 2 Compaq Presario V2414NR WiFi Card Replacement: passo 6, immagine 2 di 2
    • Use your fingernails, or plastic opening tools, to spread the metal retaining tabs on each side of the WiFi card outwards until the card pops up.
    • Pull the WiFi card out of the socket at the same angle it is now oriented.
    • When reassembling, align the offset notch on the WiFi card contacts with the tab on the socket and insert at a 30 degree angle.
Conclusione
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 348
