Salta al contenuto principale
Compaq Presario V2414NR RAM Replacement
Cosa ti serve
  1. Compaq Presario V2414NR RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR RAM Replacement: passo 2, immagine 1 di 2 Compaq Presario V2414NR RAM Replacement: passo 2, immagine 2 di 2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR RAM Replacement, RAM Cover: passo 3, immagine 1 di 2 Compaq Presario V2414NR RAM Replacement, RAM Cover: passo 3, immagine 2 di 2
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR RAM Replacement, RAM: passo 4, immagine 1 di 2 Compaq Presario V2414NR RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Use your fingers, or plastic opening tools, to spread the metal retaining tabs on each side of the RAM outwards until the module pops up.
    • Pull the module out of the socket at the same angle it is now oriented.
    • Repeat these steps to remove the second memory module.
    • When reassembling, align the offset notch on the RAM contacts with the tab on the socket and insert at a 30 degree angle.
Conclusione
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 262
