Salta al contenuto principale
Compaq Presario CQ62-215dx RAM Replacement
Cosa ti serve
  1. Compaq Presario CQ62-215dx RAM Replacement, RAM: passo 1, immagine 1 di 1
    • lay the laptop upside down.
  2. Compaq Presario CQ62-215dx RAM Replacement: passo 2, immagine 1 di 1
    • Remove the battery by pushing the lock to the left and lifting the battery from its socket.
  3. Compaq Presario CQ62-215dx RAM Replacement: passo 3, immagine 1 di 1
    • Once the battery is out, locate a panel that is underneath the battery compartment and unscrew the three 3mm screws with a Philips screwdriver.
  4. Compaq Presario CQ62-215dx RAM Replacement: passo 4, immagine 1 di 1
    • Once removed, you should have something like in this picture. Locate the current RAM.
  5. Compaq Presario CQ62-215dx RAM Replacement: passo 5, immagine 1 di 1
    • To remove the RAM, start by lifting up the first card. Grab each side of the card with two fingers as shown in the picture and pull gently until it is removed from its slot.
  6. Compaq Presario CQ62-215dx RAM Replacement: passo 6, immagine 1 di 1
    • Insert your new RAM replacement into the slot where the old one was removed. Push until you hear a small click.
  7. Compaq Presario CQ62-215dx RAM Replacement: passo 7, immagine 1 di 1
    • Push the card downward into the compartment until you hear another clicking sound.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 556
