Salta al contenuto principale
Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement
Cosa ti serve
  1. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement, Hard Drive: passo 1, immagine 1 di 1
    • First you will need to turn the laptop upside down.
  2. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: passo 2, immagine 1 di 1
    • Remove the battery by pushing the switch to the left and removing the battery from its slot.
  3. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: passo 3, immagine 1 di 1
    • Unscrew the three 3mm screws on the compartment underneath the battery.
  4. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: passo 4, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 3mm screws on the lowest compartment.
  5. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: passo 5, immagine 1 di 1
    • Use a Metal Spudger remove the panel. Underneath is where the hard drive is connected .
  6. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: passo 6, immagine 1 di 1
    • This is where you detach your old hard drive and replace with the new component.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 321
