Salta al contenuto principale
Compaq Presario CQ60-211DX Solid State Drive Replacement
Cosa ti serve
  1. Compaq Presario CQ60-211DX Solid State Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop off and disconnect all sources of power.
    • Set the laptop on a flat surface with the bottom side facing up.
  2. Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 2, immagine 1 di 3 Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 2, immagine 2 di 3 Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 2, immagine 3 di 3
    • Slide the battery release tab.
    • This will eject the battery.
    • Carefully remove the battery and set it aside.
  3. Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): passo 3, immagine 1 di 2 Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): passo 3, immagine 2 di 2
    • Use a PH1 screwdriver to unscrew the 2 screws that secure the hard drive cover.
    • Remove the cover.
  4. Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 4, immagine 1 di 2 Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 4, immagine 2 di 2
    • Unscrew the next three screws holding the hard drive in place.
    • Pull the black ribbon and slide the hard drive out of place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,010
