Salta al contenuto principale
Compaq Presario CQ60-211DX RAM (Random Access Memory) Replacement
Cosa ti serve
  1. Compaq Presario CQ60-211DX RAM (Random Access Memory)  Replacement, RAM (Random Access Memory): passo 1, immagine 1 di 1
    • Power off the CQ60 and unplug all cables connected to it.
  2. Compaq Presario CQ60-211DX RAM (Random Access Memory)  Replacement: passo 2, immagine 1 di 1
    • Using a standard #2 Phillips-head screwdriver, remove the back compartment of the CQ60 to access the motherboard.
  3. Compaq Presario CQ60-211DX RAM (Random Access Memory)  Replacement: passo 3, immagine 1 di 1
    • Use your fingers to push the retention clips away from the RAM sticks, and carefully pull out the old RAM.
  4. Compaq Presario CQ60-211DX RAM (Random Access Memory)  Replacement: passo 4, immagine 1 di 1
    • Carefully insert the new RAM, and ensure that it is placed in the correct slots.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 852
