Salta al contenuto principale
Compaq Presario CQ60-211DX Display Assembly Replacement
Cosa ti serve
  1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: passo 1, immagine 1 di 1
    • Start by making sure the CQ60 is powered down and that the disk drive is empty.
    • Flip the device over and remove the battery.
  2. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 2, immagine 1 di 2 Compaq Presario CQ60-211DX Display Assembly Replacement: passo 2, immagine 2 di 2
    • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
    • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
  3. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 3, immagine 1 di 2 Compaq Presario CQ60-211DX Display Assembly Replacement: passo 3, immagine 2 di 2
    • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
  4. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 4, immagine 1 di 1
    • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
  5. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 5, immagine 1 di 1
    • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
  6. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 6, immagine 1 di 1
    • Pull the frame forward, and then unscrew the three screws on each side.
  7. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 7, immagine 1 di 1
    • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
Conclusione
2 Commenti
My laptop model Compaq predario cq61 h
Rashid 007 - Replica
Computer on but display light of computer is running
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,280
