Salta al contenuto principale
Compaq Presario CQ58 Cooling / FAN system cleaning
Cosa ti serve
Panoramica Video
  1. Compaq Presario CQ58 Cooling / FAN system cleaning, Cooling / FAN system cleaning: passo 1, immagine 1 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning, Cooling / FAN system cleaning: passo 1, immagine 2 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning, Cooling / FAN system cleaning: passo 1, immagine 3 di 3
    • Switch-off the laptop and remove the battery.
    • Remove the memory cover.
  2. Compaq Presario CQ58 Cooling / FAN system cleaning: passo 2, immagine 1 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 2, immagine 2 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 2, immagine 3 di 3
    • Remove the HDD cover.
    • Unpin the HDD.
  3. Compaq Presario CQ58 Cooling / FAN system cleaning: passo 3, immagine 1 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 3, immagine 2 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 3, immagine 3 di 3
    • Near to the WiFi card you can see one screw hole with a keyboard symbol. This screw holds the Keyboard.
    • To remove the Keyboard, you must open 5X locking clips.
  4. Compaq Presario CQ58 Cooling / FAN system cleaning: passo 4, immagine 1 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 4, immagine 2 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 4, immagine 3 di 3
    • Under the Keyboard there are:
    • 4x M2.5x5.0 screws
    • Mouse flex cable connector
    • Power On button flex cable connector.
    • Unscrew the screws on the bottom side of the laptop:
    • 13x M2.5x5.0
    • 3x M2.5x3.0
  5. Compaq Presario CQ58 Cooling / FAN system cleaning: passo 5, immagine 1 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 5, immagine 2 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 5, immagine 3 di 3
    • Use a plastic tool to separate and remove the upper case.
    • Unscrew 5x screws and disconnect:
    • LCD Display cable
    • Additional USB board cable
    • Power jack cable
    • Loudspeaker cable
    • SATA HDD cable
  6. Compaq Presario CQ58 Cooling / FAN system cleaning: passo 6, immagine 1 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 6, immagine 2 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 6, immagine 3 di 3
    • Move a little the LCD display hinge.
    • Remove the board by starting from the right side.
  7. Compaq Presario CQ58 Cooling / FAN system cleaning: passo 7, immagine 1 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 7, immagine 2 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 7, immagine 3 di 3
    • Remove the cooling system.
  8. Compaq Presario CQ58 Cooling / FAN system cleaning: passo 8, immagine 1 di 2 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 8, immagine 2 di 2
    • Open the fan and clean the dust from inside with a soft brush.
  9. Compaq Presario CQ58 Cooling / FAN system cleaning: passo 9, immagine 1 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 9, immagine 2 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 9, immagine 3 di 3
    • Clean the old thermal compound (from the CPU and from the heat-sink system).
    • Put a new thermal compound and start with reassembling.
  10. Compaq Presario CQ58 Cooling / FAN system cleaning: passo 10, immagine 1 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 10, immagine 2 di 3 Compaq Presario CQ58 Cooling / FAN system cleaning: passo 10, immagine 3 di 3
    • When you start the system, check that fan is working.
    • Did you do it successfully?
Conclusione
Altre 9 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
192.056 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.525 Guide realizzate
7 Commenti
A brilliant demonstration really clear and well photographed, only one problem how the !&&* do you get the screws undone mine seem fixed solid
please let me into the secret if there is one.
thanks for the demo anyway.
JF.
alma francomb - Replica
Thanks for this!
My Son and I have just successfully removed, cleaned and replaced the fan in his laptop by following the instructions above.
Great work.
David Cooper - Replica
Thank you a lot !!!!
lone guldbæk kvist - Replica
I think i did something wrong? I completed all the steps but my fan (which is brand new) keeps making this scary loud wizzy noise instead of a hum and did i not tightem the screws enough or they to tight?? Please help!
Layla - Replica
Please ensure the fan metal case is not bent and ensure the fan is properly mounted. If this doesn’t solve your problem, your new fan is defective.
Brendan -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 64
Tutti i Tempi: 24,884
