Salta al contenuto principale
Compaq Mini 110 Top Cover Replacement
Cosa ti serve
  1. Compaq Mini 110 Top Cover Replacement, Battery: passo 1, immagine 1 di 2 Compaq Mini 110 Top Cover Replacement, Battery: passo 1, immagine 2 di 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
  2. Compaq Mini 110 Top Cover Replacement: passo 2, immagine 1 di 3 Compaq Mini 110 Top Cover Replacement: passo 2, immagine 2 di 3 Compaq Mini 110 Top Cover Replacement: passo 2, immagine 3 di 3
    • Push both tabs inward simultaneously and slide the battery out.
  3. Compaq Mini 110 Top Cover Replacement, RAM: passo 3, immagine 1 di 2 Compaq Mini 110 Top Cover Replacement, RAM: passo 3, immagine 2 di 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
  4. Compaq Mini 110 Top Cover Replacement: passo 4, immagine 1 di 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
  5. Compaq Mini 110 Top Cover Replacement, Keyboard: passo 5, immagine 1 di 2 Compaq Mini 110 Top Cover Replacement, Keyboard: passo 5, immagine 2 di 2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Compaq Mini 110 Top Cover Replacement: passo 6, immagine 1 di 2 Compaq Mini 110 Top Cover Replacement: passo 6, immagine 2 di 2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Compaq Mini 110 Top Cover Replacement: passo 7, immagine 1 di 2 Compaq Mini 110 Top Cover Replacement: passo 7, immagine 2 di 2
    • Unscrew the screw for the bottom case located in the RAM compartment.
  8. Compaq Mini 110 Top Cover Replacement: passo 8, immagine 1 di 2 Compaq Mini 110 Top Cover Replacement: passo 8, immagine 2 di 2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
  9. Compaq Mini 110 Top Cover Replacement, Hard Drive: passo 9, immagine 1 di 1
    • Remove the three screws holding the panel in place.
  10. Compaq Mini 110 Top Cover Replacement: passo 10, immagine 1 di 2 Compaq Mini 110 Top Cover Replacement: passo 10, immagine 2 di 2
    • Pull up on the tab to remove the hard drive.
  11. Compaq Mini 110 Top Cover Replacement, Top Cover: passo 11, immagine 1 di 1
    • Remove the eight screws that are from the plastic top cover.
  12. Compaq Mini 110 Top Cover Replacement: passo 12, immagine 1 di 3 Compaq Mini 110 Top Cover Replacement: passo 12, immagine 2 di 3 Compaq Mini 110 Top Cover Replacement: passo 12, immagine 3 di 3
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
  13. Compaq Mini 110 Top Cover Replacement: passo 13, immagine 1 di 2 Compaq Mini 110 Top Cover Replacement: passo 13, immagine 2 di 2
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
Conclusione
Altre 4 persone hanno completato questa guida.
alea
Membro da: 10/06/10
1.405 Reputazione
14 Guide realizzate
Cal Poly, Team 22-2, Maness Fall 2010 Membro di Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 8,232
