Salta al contenuto principale
Compaq Evo N400c Backup Battery Replacement
Cosa ti serve
  1. Compaq Evo N400c Backup Battery Replacement, Disconnect batteries: passo 1, immagine 1 di 3 Compaq Evo N400c Backup Battery Replacement, Disconnect batteries: passo 1, immagine 2 di 3 Compaq Evo N400c Backup Battery Replacement, Disconnect batteries: passo 1, immagine 3 di 3
    • Assuming that you already have your Multimedia Expansion Base detached(if you have it), disconnect both the handle battery(the one that sticks out) and the system battery(again, if you have those)
    • System battery clips
    • Handle battery clips
  2. Compaq Evo N400c Backup Battery Replacement, Remove screws: passo 2, immagine 1 di 3 Compaq Evo N400c Backup Battery Replacement, Remove screws: passo 2, immagine 2 di 3 Compaq Evo N400c Backup Battery Replacement, Remove screws: passo 2, immagine 3 di 3
    • You will need to remove the keyboard and palmrest screws, which require the use of a Torx T8 or flathead screwdriver.
    • If your N400c or N410c still has this screw, then you must use a screwdriver of the aforementioned Torx size.
    • If you find any Philip head screws holding the keyboard and/or palmrest in place instead of the Torx ones, then the system most likely had those screws replaced at one point in time.
  3. Compaq Evo N400c Backup Battery Replacement: passo 3, immagine 1 di 3 Compaq Evo N400c Backup Battery Replacement: passo 3, immagine 2 di 3 Compaq Evo N400c Backup Battery Replacement: passo 3, immagine 3 di 3
    • Carefully lift up the front left and right corners,
    • then you will need to use a small plastic opening tool to lift 2 clips on the front. The palmrest should flip open and rest over the keyboard.
    • If you have a N410c, skip this point and go on to the next one. If you have a N400c, disconnect the ribbon cable that connects the trackpoint to its buttons on the palmrest,
    • Lift the palmrest and then you can flip the keyboard over onto the screen, then you can see and disconnect the backup battery.
  4. Compaq Evo N400c Backup Battery Replacement, Building your own backup battery: passo 4, immagine 1 di 1
    • If you bought a pre-made backup battery, you can skip this step and "follow these steps in reverse order".
    • Otherwise, if you have a CR2016, CR2025 or similar size/thickness coin cell, then read for how easy it is to tape the contacts to your battery.
    • cut open the sleeve and carefully rip away the tabs from the old battery.
    • Hold the contacts to the battery as you tape them together.
    • Red = positive | Black = negative
    • Don't put too much tape, but wrap it tightly. Of course don't do it too tight.
Conclusione
Kevin Bhasi
Membro da: 12/26/14
1.262 Reputazione
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,914
