Salta al contenuto principale
Compaq Evo N1000v Heat Sink Replacement
Cosa ti serve
  1. Compaq Evo N1000v Heat Sink Replacement, LED Cover: passo 1, immagine 1 di 1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Heat Sink Replacement: passo 2, immagine 1 di 1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Heat Sink Replacement: passo 3, immagine 1 di 1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Heat Sink Replacement: passo 4, immagine 1 di 1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Heat Sink Replacement: passo 5, immagine 1 di 1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Heat Sink Replacement: passo 6, immagine 1 di 1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Heat Sink Replacement: passo 7, immagine 1 di 1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Heat Sink Replacement: passo 8, immagine 1 di 2 Compaq Evo N1000v Heat Sink Replacement: passo 8, immagine 2 di 2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Heat Sink Replacement, Keyboard: passo 9, immagine 1 di 1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Heat Sink Replacement: passo 10, immagine 1 di 1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Heat Sink Replacement: passo 11, immagine 1 di 1
    • Remove the keyboard.
  12. Compaq Evo N1000v Heat Sink Replacement, Heat Sink: passo 12, immagine 1 di 1
    • Disconnect the cable connecting the fan to the system board.
  13. Compaq Evo N1000v Heat Sink Replacement: passo 13, immagine 1 di 1
    • Remove the four screws from the heat sink.
  14. Compaq Evo N1000v Heat Sink Replacement: passo 14, immagine 1 di 1
    • Pull the the heat sink up and out of the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
kim
Membro da: 04/14/10
59 Reputazione
3 Guide realizzate
Cal Poly, Team 29-74, Johann Spring 2010 Membro di Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,996
