Salta al contenuto principale
Commodore 64 VIC Chip Replacement
Cosa ti serve
  1. Attenzione: i passaggi 1-2 provengono da una guida contrassegnata come in corso.
    Commodore 64 VIC Chip Replacement, Removing screws: passo 1, immagine 1 di 3 Commodore 64 VIC Chip Replacement, Removing screws: passo 1, immagine 2 di 3 Commodore 64 VIC Chip Replacement, Removing screws: passo 1, immagine 3 di 3
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 VIC Chip Replacement, Opening: passo 2, immagine 1 di 2 Commodore 64 VIC Chip Replacement, Opening: passo 2, immagine 2 di 2
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: passo 3, immagine 1 di 2 Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: passo 3, immagine 2 di 2
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
  4. Commodore 64 VIC Chip Replacement, Pull up the VIC plate: passo 4, immagine 1 di 2 Commodore 64 VIC Chip Replacement, Pull up the VIC plate: passo 4, immagine 2 di 2
    • 2. Without using any tools prop up the metal VIC plate with both hands to expose the VIC chip.
  5. Commodore 64 VIC Chip Replacement, Removing the Chip: passo 5, immagine 1 di 2 Commodore 64 VIC Chip Replacement, Removing the Chip: passo 5, immagine 2 di 2
    • 3. Use a Phillips screwdriver to pry up the VIC chip. Then, use your hands and with small pressure pull it away to remove it from the motherboard.
    • You can insert a new VIC chip by making it clip back in on the board
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 13-6, Staggers Fall 2014 Membro di USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Membri
15 Guide realizzate
Un commento
It's awesome to see that people care enough about these machines to make repair guides about them! Great job!
[deleted] - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,636
