Salta al contenuto principale
Comment forcer le redémarrage de l'iPhone X
Cosa ti serve
  1. Comment forcer le redémarrage de l'iPhone X, Comment forcer le redémarrage de l'iPhone X: passo 1, immagine 1 di 1
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone X: passo 2, immagine 1 di 1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
Linea Traguardo
Altre 126 persone hanno completato questa guida.
13 Commenti
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - Replica
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - Replica
good share. thanks.
MelissaR - Replica
What is the other way?
sa sas - Replica
will it delete all data from my iPhone?
_TR0xuu_ - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 79
Ultimi 7 Giorni: 360
Ultimi 30 Giorni: 1,509
Tutti i Tempi: 347,906
