Salta al contenuto principale
Comment forcer le redémarrage de l'iPhone 8 Plus
Cosa ti serve
  1. Comment forcer le redémarrage de l'iPhone 8 Plus, Comment forcer le redémarrage de l'iPhone 8 Plus: passo 1, immagine 1 di 1
    • appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
    The picture makes it look like you need to start this process with the phone turned on already, but I think you need to start with it powered off - that’s the only way that long-pressing the power button in Step 2 causes the Apple logo to appear.
    Owen Edwards - Replica
    For an iPhone 8, step #3 is to press and hold the right-side button. Continue holding the button down until the apple logo appears, then release.
    sjf - Replica
    what if the apple logo appears but nothing else happens. it just keeps showing the logo.
    LeRoyal - Replica
  2. Comment forcer le redémarrage de l'iPhone 8 Plus: passo 2, immagine 1 di 1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    How can i have apple id and password to fix my phone
    Mhreteab Adresom - Replica
Linea Traguardo
Altre 65 persone hanno completato questa guida.
2 Commenti
What if my side power button doesn’t work?
Alex Busnelli - Replica
Are there any preconditions? Like should the iPhone be ON before step 1?
Are there any side effects? Like resetting momory, settings, etc?
Eric Bolinger - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 26
Ultimi 7 Giorni: 145
Ultimi 30 Giorni: 591
Tutti i Tempi: 40,018
