Salta al contenuto principale
Comfort Zone CZ6C Fan Blades Replacement
Cosa ti serve
  1. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: passo 1, immagine 1 di 3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: passo 1, immagine 2 di 3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: passo 1, immagine 3 di 3
    • The metal cage is kept in place by three plastic tabs on the plastic body. Focus your pulling around these tabs to make the job easier.
    • In order to remove the metal cage, place one hand firmly on the back plastic body and your other hand on the metal cage.
    • Now work your way around the edge of the fan cage and pull it away from the plastic body.
  2. Comfort Zone CZ6C Fan Blades Replacement: passo 2, immagine 1 di 2 Comfort Zone CZ6C Fan Blades Replacement: passo 2, immagine 2 di 2
    • To remove the fan blade, reach behind it and slowly pull it towards you.
    • If the fan blade axle has any hair or dirt, then clean it with a cloth to avoid further fan blade blockage.
    • If you are having difficulty removing the fan blade, then generously apply WD-40 to the fan blade axle.
Conclusione
Cal Poly, Team 17-5, Forte Spring 2015 Membro di Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Membri
5 Guide realizzate
2 Commenti
Where does one buy the replacement blades?
Frank Gould - Replica
where does one buy the replacement blades??
Luis Marrero - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 5,823
