Introduzione
Sostituire la batteria dell'orologio Armitron richiederà lo smontaggio della maggior parte dell'orologio.
Cosa ti serve
Rimuovi il cinturino posteriore.
Svita le quattro viti a croce Phillips a testa bombata da 1,7 mm.
Per rimontare il tuo dispositivo, segui le istruzioni in ordine inverso.
Altre 11 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Daniele Carminati ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
8 Commenti
what about the after battery replacement short circuit to reset it? that’s the hard part that totally is unclear!
what about the post battery replacement short circuit reset?! that’s the hard part that’s completely unclear and confusing!
my comments don’t seem to be working.
I agree that these instructions are very deficient when describing how to reset the battery. I just spent 1/2 hour resetting an Amitron MD0699. One is supposed to bridge about a 2 mm gap between 2 vertical bands of metal. The space to approach this is very small. A normal paper clip tip is too narrow for this purpose. A large metallic paper clip tip might work, but you will have to prove that the metal is conductive. My micro screwdriver set didn’t work; I didn’t realize the metal was non conductive til I tested it with an electrometer. In the end, the electrometer tip was just the right size. I reassuring little chime rang when the reset occurs. All these little fine points would have made the original post useful.
I took the whole watch assembly out of the case and was able to short out the 2 tabs with a piece of stripped 16 ga stranded copper wire.
