Introduzione
Segui questa guida per forzare il riavvio del tuo iPhone 6s quando è bloccato e non risponde. Il riavvio forzato è molto semplice e non richiede l'utilizzo di attrezzi.
Premi e tieni premuto il tasto Home.
Mentre tieni premuto il tasto Home, premi e tieni premuto il tasto di accensione.
Continua a tenere premuti entrambi i tasti per circa 10 secondi finché non appare il logo Apple.
What do u do then it gust goes black and won't turn on
Another question. What to do when these force start instructions result in a dead black, unchanged screen?
So I’ve replaced the screen but still have just a blank black screen, when I try turning it on it has the plug in and charge icon pops up, and goes off when I unplug, but nothin else will display on screen!!! HELPPPP!! PLEASE!!
Altre 276 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
22 Commenti
I dropped my phone in the garage it locked my screen when I turn it on it has lines across real colorful but locked I m not able to retrieve contacts or photos from it…is there any hope,? I had to purchase another phone same one iPhone 6s I really need my contacts and photos from this phone?
my home button doesnt work, how do i do this without the home button?
its not working for me I been trying it and just did again any other suggestions when u have no ride
Swollen battery kept the home button from properly working on my phone, it spread the case apart slightly. Do you have battery problems?
If the home button was malfunction, how to force restart?
Brillant guide. Was my first time opening up an iPhone for repair. Guess what? It even works afterwards, which, I have to admit, is rarely the case when I try to fix something. Thanks
Kit fit great. Be patient when installing. Would recommend
i did this with my phone and a bunch of grey lines appeared and then it went completely black and no logo came up?
It doesn't work
what if the homebutton does not work? Is there a way to restart then?
i got so incredibly lucky. i actually misplaced two of the screws belonging to the panel that holds down the 3 display connector cables, saying “&&^& it” and only using the two at my disposal. fearing having to buy a new phone (having completed all the steps), i forced a restart and… it works perfectly. no common issues that i had seen in any of these comments. thanks so much!!
1244234433
as
on/off bottom on right hand side does not work after battery change
is there any possibility to make a hard reset?
on my mcbook in finder it is not possible
Se queda la manzana a reiniciarlo y de ahi no pasa😢😢
Gevebdksjebrnfkkr
Hhhhhhjjjjjj
