Salta al contenuto principale
ComNet Ericsson Panther 600P Speaker Replacement
Cosa ti serve
  1. ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: passo 1, immagine 1 di 3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: passo 1, immagine 2 di 3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: passo 1, immagine 3 di 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Speaker Replacement, Antenna: passo 2, immagine 1 di 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Speaker Replacement, Dials: passo 3, immagine 1 di 1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: passo 4, immagine 1 di 3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: passo 4, immagine 2 di 3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: passo 4, immagine 3 di 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Speaker Replacement, Speaker: passo 5, immagine 1 di 2 ComNet Ericsson Panther 600P Speaker Replacement, Speaker: passo 5, immagine 2 di 2
    • Locate the device's speaker inside the front panel of the exterior case.
    • Locate the display and speaker stabilizer.
    • Lift the stabilizer up from the bottom and pull the stabilizer out of case.
  6. ComNet Ericsson Panther 600P Speaker Replacement: passo 6, immagine 1 di 3 ComNet Ericsson Panther 600P Speaker Replacement: passo 6, immagine 2 di 3 ComNet Ericsson Panther 600P Speaker Replacement: passo 6, immagine 3 di 3
    • Locate the two 3.75mm screws holding the speaker to the exterior case.
    • Using a T15 Torx screwdriver, unscrew the 3.75mm screws.
  7. ComNet Ericsson Panther 600P Speaker Replacement: passo 7, immagine 1 di 2 ComNet Ericsson Panther 600P Speaker Replacement: passo 7, immagine 2 di 2
    • Lift up on the bottom of the speaker to detach the speaker.
    • Pull the speaker out of the case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 193
