Introduzione
With a few tools, a little bit of time, and a moderate degree of commitment, you can replace a damaged display on ComNet Ericsson Panther 600P.
Cosa ti serve
Look for the release button on the back of the radio.
Press the button and pull down on the battery at the same time. The battery will come free.
Using a T15 Torx screwdriver, unscrew the two screws.
Using a plastic opening tool, pry the internal case from the external case.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Pull ribbon with tweezers to detach from back panel.
Conclusione
