Salta al contenuto principale
Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement
Cosa ti serve
  1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: passo 1, immagine 1 di 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: passo 1, immagine 2 di 2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 2, immagine 1 di 1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 3, immagine 1 di 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 3, immagine 2 di 2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 4, immagine 1 di 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 4, immagine 2 di 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 4, immagine 3 di 3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: passo 5, immagine 1 di 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: passo 5, immagine 2 di 2
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 6, immagine 1 di 2 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 6, immagine 2 di 2
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 7, immagine 1 di 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 7, immagine 2 di 3 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 7, immagine 3 di 3
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
Conclusione
Mathew Merrick
Membro da: 09/17/18
169 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 570
