Salta al contenuto principale
Coleman Rechargeable Fluorescent Twin Tube Battery Replacement
Cosa ti serve
  1. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: passo 1, immagine 1 di 2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: passo 1, immagine 2 di 2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 2, immagine 1 di 1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 3, immagine 1 di 2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 3, immagine 2 di 2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 4, immagine 1 di 3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 4, immagine 2 di 3 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 4, immagine 3 di 3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
Conclusione
Sean
Membro da: 09/17/18
265 Reputazione
2 Guide realizzate
Un commento
Sean, I’m facing a dead battery in my Coleman twin tube fluorescent lantern also. Your directions are spot on except my battery seems to be glued in with super glue! I’ve tried a heat gun and all my strength but my battery won’t come loose. I find it hard to pry under the battery because of the shape of the plastic partitions around the battery. How did you get the battery unstuck?
BilMcKelvy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 97
Tutti i Tempi: 4,650
