Salta al contenuto principale
ColecoVision Motherboard Replacement
Cosa ti serve
  1. ColecoVision Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Start by laying the console face down.
    • Remove the eight 15mm Phillips #1 screws from the bottom of the device.
  2. ColecoVision Motherboard Replacement: passo 2, immagine 1 di 2 ColecoVision Motherboard Replacement: passo 2, immagine 2 di 2
    • Flip the console back over.
    • Lift the front panel off. I would reccomended using a metal spudger along the rim of the top to safely remove it and set it aside.
  3. ColecoVision Motherboard Replacement: passo 3, immagine 1 di 2 ColecoVision Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the two 15mm Phillips #1 screws holding the casing in place.
    • Carefully lift the casing from the motherboard.
  4. ColecoVision Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the center Phillips #1 screw near the cartridge slot.
    • Remove the second Phillips #1 screw near the RAM chips.
    • Carefully lift and remove the motherboard.
Conclusione
Krystalina
Membro da: 10/24/18
121 Reputazione
1 Guida realizzata
UW Tacoma, Team S1-G2, Rose Fall 2018 Membro di UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,585
