Salta al contenuto principale
Coby Kyros MID9742 Battery Replacement
Cosa ti serve
  1. Coby Kyros MID9742 Battery Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Coby Kyros MID9742 Battery Replacement: passo 2, immagine 1 di 1
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Coby Kyros MID9742 Battery Replacement: passo 3, immagine 1 di 1
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  4. Coby Kyros MID9742 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
Conclusione
Ian Swett
Membro da: 03/11/15
597 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 755
