Salta al contenuto principale
Coby Kyros MID7125 Speaker Replacement
Cosa ti serve
  1. Coby Kyros MID7125 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Use opening too to make small opening in the side of the device.
    • Use plastic opening tool to pry the rest of the panel off.
  2. Coby Kyros MID7125 Speaker Replacement: passo 2, immagine 1 di 1
    • Once inside the device, locate the speakers on the inside of the back panel.
  3. Coby Kyros MID7125 Speaker Replacement: passo 3, immagine 1 di 1
    • Use spudger to pry one speaker up off of the back panel.
  4. Coby Kyros MID7125 Speaker Replacement: passo 4, immagine 1 di 1
    • Desolder the soldering points that connect the speaker to the motherboard.
  5. Coby Kyros MID7125 Speaker Replacement: passo 5, immagine 1 di 1
    • Use a soldering iron to solder the wires of the new speaker to the motherboard.
    • Make sure, when soldering, to connect the red wire to the red and the black wire to the black.
  6. Coby Kyros MID7125 Speaker Replacement: passo 6, immagine 1 di 1
    • Click the new speaker into the spot where you removed the old speaker.
    • Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
Conclusione
Nicole Connelly
Membro da: 10/20/16
1 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 5-2, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 132
