Salta al contenuto principale
Coby DVD209 DVD Laser Reader Replacement
Cosa ti serve
  1. Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: passo 1, immagine 1 di 3 Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: passo 1, immagine 2 di 3 Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: passo 1, immagine 3 di 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 DVD Laser Reader Replacement: passo 2, immagine 1 di 3 Coby DVD209 DVD Laser Reader Replacement: passo 2, immagine 2 di 3 Coby DVD209 DVD Laser Reader Replacement: passo 2, immagine 3 di 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 DVD Laser Reader Replacement: passo 3, immagine 1 di 3 Coby DVD209 DVD Laser Reader Replacement: passo 3, immagine 2 di 3 Coby DVD209 DVD Laser Reader Replacement: passo 3, immagine 3 di 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 DVD Laser Reader Replacement, DVD Laser Reader: passo 4, immagine 1 di 2 Coby DVD209 DVD Laser Reader Replacement, DVD Laser Reader: passo 4, immagine 2 di 2
    • Remove the two 6.35mm screws circled in black with a #1 Philips head screwdriver.
    • Remove one 4mm screw circled in red with a #1 Philips head screwdriver.
  5. Coby DVD209 DVD Laser Reader Replacement: passo 5, immagine 1 di 3 Coby DVD209 DVD Laser Reader Replacement: passo 5, immagine 2 di 3 Coby DVD209 DVD Laser Reader Replacement: passo 5, immagine 3 di 3
    • There are three small 4.5mm springs that can be easily lost. Be careful when lifting up the railing assembly to make sure you don't lose them.
    • The location of the springs are circled.
    • Using two plastic tool removers, lift the two rails up at an angle. Keep the rods angled as shown.
    • The rail at the top of the picture is 82mm and the rail at the bottom of the picture is 65mm.
  6. Coby DVD209 DVD Laser Reader Replacement: passo 6, immagine 1 di 2 Coby DVD209 DVD Laser Reader Replacement: passo 6, immagine 2 di 2
    • Be careful not to lose the spring at the top of the laser.
    • Lift the laser assembly out of the fixture.
  7. Coby DVD209 DVD Laser Reader Replacement: passo 7, immagine 1 di 3 Coby DVD209 DVD Laser Reader Replacement: passo 7, immagine 2 di 3 Coby DVD209 DVD Laser Reader Replacement: passo 7, immagine 3 di 3
    • Remove the rails from the disk reader.
    • Once the top rail is removed, the white gear will come off and under it will be one of the springs.
Conclusione
Yufay Chow
Membro da: 01/23/12
92 Reputazione
4 Guide realizzate
Cal Poly, Team 10-36, Amido Winter 2012 Membro di Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 822
