Salta al contenuto principale
Coby DVD209 4-Pin Ribbon Cable Replacement
Cosa ti serve
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: passo 1, immagine 1 di 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: passo 1, immagine 2 di 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: passo 1, immagine 3 di 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: passo 2, immagine 1 di 3 Coby DVD209 4-Pin Ribbon Cable Replacement: passo 2, immagine 2 di 3 Coby DVD209 4-Pin Ribbon Cable Replacement: passo 2, immagine 3 di 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: passo 3, immagine 1 di 3 Coby DVD209 4-Pin Ribbon Cable Replacement: passo 3, immagine 2 di 3 Coby DVD209 4-Pin Ribbon Cable Replacement: passo 3, immagine 3 di 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: passo 4, immagine 1 di 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: passo 4, immagine 2 di 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: passo 4, immagine 3 di 3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
Conclusione
Yufay Chow
Membro da: 01/23/12
92 Reputazione
4 Guide realizzate
Cal Poly, Team 10-36, Amido Winter 2012 Membro di Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,016
