Cosa ti serve
Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
Remove the wire from the circuit board.
Position the DVD player so that the side with golden circuit board, where the power cord was plugged into, is closest to you.
Remove the black wire with the 6-pin white adapter, which is adjacent to the other three pin adapter wires on the golden circuit board.
De-solder the electrical components contained in the red rectangles from the green circuit board, which is the second one you removed.
