Salta al contenuto principale
Coby DVD-R11000 3-Pin Power Cable Replacement
Cosa ti serve
  1. Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: passo 1, immagine 1 di 3 Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: passo 1, immagine 2 di 3 Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: passo 1, immagine 3 di 3
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 3-Pin Power Cable Replacement: passo 2, immagine 1 di 3 Coby DVD-R11000 3-Pin Power Cable Replacement: passo 2, immagine 2 di 3 Coby DVD-R11000 3-Pin Power Cable Replacement: passo 2, immagine 3 di 3
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
  3. Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: passo 3, immagine 1 di 2 Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: passo 3, immagine 2 di 2
    • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
    • Remove the wire from the circuit board.
Conclusione
Andrew
Membro da: 10/22/14
501 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Membro di UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 436
