Salta al contenuto principale
Cobra 29 LTD Classic Knobs Replacement
Cosa ti serve
  1. Cobra 29 LTD Classic Knobs Replacement, Power Cable: passo 1, immagine 1 di 2 Cobra 29 LTD Classic Knobs Replacement, Power Cable: passo 1, immagine 2 di 2
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Knobs Replacement: passo 2, immagine 1 di 2 Cobra 29 LTD Classic Knobs Replacement: passo 2, immagine 2 di 2
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Knobs Replacement, Microphone: passo 3, immagine 1 di 2 Cobra 29 LTD Classic Knobs Replacement, Microphone: passo 3, immagine 2 di 2
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  4. Cobra 29 LTD Classic Knobs Replacement: passo 4, immagine 1 di 1
    • Gently unplug the microphone plug.
  5. Cobra 29 LTD Classic Knobs Replacement, Knobs: passo 5, immagine 1 di 1
    • Gently turn the middle four knobs counter-clockwise until they no longer move.
    • The middle four knobs are held in place by friction and do not have a way to keep them in the correct position. When reassembling the middle four knobs, make sure to line up the mark on the knob with the left-most mark on the front panel.
  6. Cobra 29 LTD Classic Knobs Replacement: passo 6, immagine 1 di 2 Cobra 29 LTD Classic Knobs Replacement: passo 6, immagine 2 di 2
    • Insert two plastic opening tools behind the tuning knob.
    • With some force, pry the knob off of the radio.
    • Two opening tools are needed so that you don't break the knob or connector by applying uneven force.
  7. Cobra 29 LTD Classic Knobs Replacement: passo 7, immagine 1 di 3 Cobra 29 LTD Classic Knobs Replacement: passo 7, immagine 2 di 3 Cobra 29 LTD Classic Knobs Replacement: passo 7, immagine 3 di 3
    • Repeat the above procedure with the remaining knobs.
    • The final knob will have a power knob on the end of it. When reassembling, put the power knob on last.
Conclusione
To reassemble your device, align the buttons and push them on.
Matt Williams
Membro da: 10/20/13
133 Reputazione
1 Guida realizzata
Cal Poly, Team 11-37, Amido Fall 2013 Membro di Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 21
Tutti i Tempi: 5,168
