Salta al contenuto principale
ClickN Kids Tablet Camera Replacement
Cosa ti serve
  1. ClickN Kids Tablet Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Start on the side with the camera
    • Insert a plastic opening tool into the space between the screen and the back side.
    • The screen side is black, the back side is colored
  2. ClickN Kids Tablet Camera Replacement: passo 2, immagine 1 di 1
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
    • The corners can be tricky. Make sure to separate the pieces all the way around the tablet before attempting to open it.
  3. ClickN Kids Tablet Camera Replacement: passo 3, immagine 1 di 1
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Don't open too fast, or you might damage the ribbons cables.
  4. ClickN Kids Tablet Camera Replacement: passo 4, immagine 1 di 2 ClickN Kids Tablet Camera Replacement: passo 4, immagine 2 di 2
    • Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
  5. ClickN Kids Tablet Camera Replacement: passo 5, immagine 1 di 1
    • Pull off the tape that holds the ribbon cable to the battery.
  6. ClickN Kids Tablet Camera Replacement: passo 6, immagine 1 di 2 ClickN Kids Tablet Camera Replacement: passo 6, immagine 2 di 2
    • Be careful not to damage the wires or ribbon cables.
    • Pull out the two black ends of the base on the motherboard.
    • Slide out the camera’s ribbon cable once the ends are loosened.
  7. ClickN Kids Tablet Camera Replacement: passo 7, immagine 1 di 3 ClickN Kids Tablet Camera Replacement: passo 7, immagine 2 di 3 ClickN Kids Tablet Camera Replacement: passo 7, immagine 3 di 3
    • Use a plastic opening tool to pry the camera out of its place.
Conclusione
Kevin Finney
Membro da: 03/22/15
562 Reputazione
4 Guide realizzate
Baylor, Team 4-4, Williams Spring 2015 Membro di Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 908
