Salta al contenuto principale
Cleaning/Replacing the Filters of a Split Air Conditioner
Cosa ti serve
  1. Cleaning/Replacing the Filters of a Split Air Conditioner, Filters: passo 1, immagine 1 di 3 Cleaning/Replacing the Filters of a Split Air Conditioner, Filters: passo 1, immagine 2 di 3 Cleaning/Replacing the Filters of a Split Air Conditioner, Filters: passo 1, immagine 3 di 3
    • Turn off the air conditioner using the remote controller.
    • Unplug the A/C unit from its power source.
  2. Cleaning/Replacing the Filters of a Split Air Conditioner: passo 2, immagine 1 di 2 Cleaning/Replacing the Filters of a Split Air Conditioner: passo 2, immagine 2 di 2
    • Place your hands on the edges of the lid, and pull the lid up to open it.
    • Apply force as needed in a progressive motion. A small tug might be necessary if the lid is very hard to open.
  3. Cleaning/Replacing the Filters of a Split Air Conditioner: passo 3, immagine 1 di 2 Cleaning/Replacing the Filters of a Split Air Conditioner: passo 3, immagine 2 di 2
    • Grab the filter by the small tab located at the bottom.
    • Pull the filter towards yourself to snap it out of the slot that holds it in place.
    • Pull the whole filter out of the A/C unit.
  4. Cleaning/Replacing the Filters of a Split Air Conditioner: passo 4, immagine 1 di 1
    • OPTIONAL STEP: If your filters are broken or damaged – consider buying new filters.
    • Buy filters that are specifically made for your model of the air conditioner. Otherwise, the filters might not fit into the unit or the device may not function properly.
    • Skip steps 5-7 and continue with step 8 after you’ve purchased your new filters.
  5. Cleaning/Replacing the Filters of a Split Air Conditioner: passo 5, immagine 1 di 1
    • Wash the filters under streaming water:.
    • Slide the filter from side to side to ensure every part of the filter is washed with the stream.
  6. Cleaning/Replacing the Filters of a Split Air Conditioner: passo 6, immagine 1 di 2 Cleaning/Replacing the Filters of a Split Air Conditioner: passo 6, immagine 2 di 2
    • OPTIONAL STEP: Follow this step if filters are very dirty and have lots of dust buildup on them.
    • Place your filters in a bucket with one part water and one part vinegar.
    • Leave for one hour to soak.
    • Wash the filters in circular motions with a soapy sponge.
    • Make sure you washed every part of the filter.
    • Rinse the filter thoroughly with water.
  7. Cleaning/Replacing the Filters of a Split Air Conditioner: passo 7, immagine 1 di 1
    • Place your filters on a towel in a dry room and let them completely dry out before proceeding to the next step.
    • This might take approximately 20-40 minutes.
  8. Cleaning/Replacing the Filters of a Split Air Conditioner: passo 8, immagine 1 di 2 Cleaning/Replacing the Filters of a Split Air Conditioner: passo 8, immagine 2 di 2
    • Potential for device damage: Filters must be completely dry before doing this step.
    • Make sure the small tab is located on the bottom of the filter and is facing you.
    • Place the filters back inside, pushing them forward until they click and fall back into place.
Conclusione
To reassemble your device, close the lid of the A/C and plug it into power.
Altre 3 persone hanno completato questa guida.
3 Commenti
I have EL that show me on the screen when I try to open my A/C and it doesn't work anymore. How can I repair it ? Please 🙏
Endless-love - Replica
My AC door not closed
Divya Bharathi - Replica
My split ac swing is not working / moving. How can i repair it
Rajesh Pawar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 197
Tutti i Tempi: 1,548
