Salta al contenuto principale
Cleaning/Degreasing Heat Sink
Cosa ti serve
  1. Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: passo 1, immagine 1 di 3 Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: passo 1, immagine 2 di 3 Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: passo 1, immagine 3 di 3
    • Ensure the engine is off and cooled down before starting this guide.
    • Using a 5/16" socket or wrench, remove the three bolts holding the plastic cover on to the engine.
    • Lift away the plastic cover. Note that the starter is attached to the cover and will come off with it.
  2. Cleaning/Degreasing Heat Sink: passo 2, immagine 1 di 2 Cleaning/Degreasing Heat Sink: passo 2, immagine 2 di 2
    • Using compressed air or a rag, clean debris from the flywheel.
  3. Cleaning/Degreasing Heat Sink, Cleaning/Degreasing Heat Sink: passo 3, immagine 1 di 2 Cleaning/Degreasing Heat Sink, Cleaning/Degreasing Heat Sink: passo 3, immagine 2 di 2
    • Using compressed air and a rag, clean the heat sink.
Conclusione
Aaron Correya
Membro da: 04/19/18
239 Reputazione
2 Guide realizzate
Cal Poly, Team S25-G15, Maness Spring 2018 Membro di Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 354
