Salta al contenuto principale
Cleaning the Skullcandy Mix Master DJ Adjustment Slider
Cosa ti serve
  1. Cleaning the Skullcandy Mix Master DJ Adjustment Slider, Cleaning the Skullcandy Mix Master DJ Adjustment Slider: passo 1, immagine 1 di 1
    • Remove the Skullcandy Mix Master DJ Headphones from any casing or protective gear.
  2. Cleaning the Skullcandy Mix Master DJ Adjustment Slider: passo 2, immagine 1 di 1
    • Rotate the headphones so that one of the speaker cups are facing you. Remove the four Phillips 3 mm screws along the headband cover.
  3. Cleaning the Skullcandy Mix Master DJ Adjustment Slider: passo 3, immagine 1 di 1
    • Gently remove the cover from the headband.
    • Removing the cover too fast could break the thin wire within the headband.
  4. Cleaning the Skullcandy Mix Master DJ Adjustment Slider: passo 4, immagine 1 di 1
    • Using a moist Q-tip or small towel, carefully wipe the inside of the headband sheath.
    • Be careful when cleaning to avoid damaging to the wire.
    • Do not use cleaning solvents. They may cause the plastic to break down.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 519
