Salta al contenuto principale
Classic Ripstik Caster Board Wheels Replacement
Cosa ti serve
  1. Classic Ripstik Caster Board Wheels Replacement, Wheels: passo 1, immagine 1 di 3 Classic Ripstik Caster Board Wheels Replacement, Wheels: passo 1, immagine 2 di 3 Classic Ripstik Caster Board Wheels Replacement, Wheels: passo 1, immagine 3 di 3
    • Use 2 5mm Allen Wrenches on both sides of the wheels and rotate both wrenches counterclockwise to take out the wheel, axle bolt, screw bolt, and 2 washers.
  2. Classic Ripstik Caster Board Wheels Replacement: passo 2, immagine 1 di 3 Classic Ripstik Caster Board Wheels Replacement: passo 2, immagine 2 di 3 Classic Ripstik Caster Board Wheels Replacement: passo 2, immagine 3 di 3
    • Take off the screw bolt on one end and the axle bolt on the other end.
    • Once you disassemble, make sure to save the bolts and washers in a safe place. You will use them for the new wheels.
  3. Classic Ripstik Caster Board Wheels Replacement: passo 3, immagine 1 di 2 Classic Ripstik Caster Board Wheels Replacement: passo 3, immagine 2 di 2
    • Slide the axle bolt through the hole on the outside and place the washer on the inside.
  4. Classic Ripstik Caster Board Wheels Replacement: passo 4, immagine 1 di 2 Classic Ripstik Caster Board Wheels Replacement: passo 4, immagine 2 di 2
    • Slide the axle bolt out just enough to place the wheel in the middle.
    • Slide the axle bolt through the middle of the wheel to hold the wheel in place.
    • It is easier to slide the bolt through the wheel if the wheel is being placed sideways.
  5. Classic Ripstik Caster Board Wheels Replacement: passo 5, immagine 1 di 2 Classic Ripstik Caster Board Wheels Replacement: passo 5, immagine 2 di 2
    • Place the second washer in between the wheel and the caster wall.
  6. Classic Ripstik Caster Board Wheels Replacement: passo 6, immagine 1 di 2 Classic Ripstik Caster Board Wheels Replacement: passo 6, immagine 2 di 2
    • Insert the screw bolt through the outside of the caster wall to go through the washer and the wheel.
  7. Classic Ripstik Caster Board Wheels Replacement: passo 7, immagine 1 di 3 Classic Ripstik Caster Board Wheels Replacement: passo 7, immagine 2 di 3 Classic Ripstik Caster Board Wheels Replacement: passo 7, immagine 3 di 3
    • Much like step 1, use 2 allen wrenches to screw in the wheel and secure it in place.
    • When screwing it, it is easier to hold one hand firm while rotating the other wrench clockwise to tighten.
Conclusione
To replace your old RipStik wheels with brand new ones. Simply follow these steps and enjoy a brand-new ride!
JairoSantos
Membro da: 04/03/23
195 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 36
Tutti i Tempi: 333
